Alrightim rebuilding my block and I have cameto a hault... Whats the tool you use to prime the crankshaft w/ oil when installing it so it wont have a dry start and wroup everything?
You will learn by doing it 'stupid', yes, bet you learn a lot more by by doing it 'correctly', and your wallet will thank you for it. BoncoBabe was simply pointing out that your questions indicate a lack of even the most basic and fundamental understanding of engine rebuilding and assembly...and you have a long way to go before its properly finished yet. Did you plastigage the crank bearings to verify proper bearing clearance?..do you have a good quality torque wrench for rod, main and head bolts and know what the torque on each must be? Head bolt torque sequence?..you learn by doing it stupid
