whenever i start getting into a higher gear and high rpms my truck starts bogging out like rpms are trying to go up and they just leep shaking up and down and when it happens you can feel it in the way the truck drives map sensor is fine and what else should i check or could it just be the tranny bad or something idk i just need helpppp
Check your plug wires for any breaks that could be shorting somewhere.
It sounds like you might be trying to describe a bog under a load. Is that right? If so, I dealt with that a few years ago with a bad plug wire.
my bko ate my money
just bad english......i cant read it either...........but i think its a prob of when it shifts it bounces his truck up and down, he says the MAP sensor is good, and wonders if its just the tranny goin out, i aint got an answer....im tired of trannys for now
