1 - 3 of 3 Posts
Does anyone have any pics of the ProComp dual steering stabilizer kit mounted on their Bronco? The instructions are CRAP. I called ProComp and spoke to a tech support person and they were CRAP. A photo would suffice. :beer
I need the same answer. I have these in my garage and I'm still running just the single because I can't figure it out.
[/URL][/IMG]
I managed to figure it out, in the end. Rough steps:
  1. Detach metal brake line from clips on front axle
  2. Position larger of 2 brackets on axle and run 2 U-bolts into it from beneath brake line.
  3. Position smaller of 2 brackets on tie rod and run 3 U-bolts into it from behind tie rod.
  4. Ensure 1" of shock is exposed at full crank to the right.
  5. Ensure no contact between shock body and tie rod by moving steering wheel throughout range of motion, from endpoint to endpoint.
  6. Try to get shocks stanchions to face upward as much as possible.
https://scontent-1.22773.fna.fbcdn.net/hphotos-xfp1/t31.0-8/10981313_10153015502416357_8011206621142011223_o.jpg
1 - 3 of 3 Posts
