1 - 8 of 8 Posts
Project '84 is going well thanks to you guys, Haynes manual, beer, & band-aids.
Today went through inspection passed emission portion but failed for "sharp body edges"
I have rust holes over wheel wells and a tad in bottom corner of the door jamb.
What's cheapest way to patch and smooth these holes? First thought was fender flares but @ $200+ , I have to find another route.
Thanks again
If you want really cheap, you could do what i did just as a quick fix, I ground down the rough parts and filled the holes with foam filler, let dry and cut it to shape with a razor blade and sanded, then coated with primer. It has helped to slow down the rust too.
Just a suggestion
1 - 8 of 8 Posts
