181 - 192 of 192 Posts
I've got those drivelines with the parts you gave me... were they all front or rear though? I could even give you one out of the parts rig ('79), if you're over in my neck of the woods.
Project STINKY Superviser
Discussion Starter #182
I need a rear driveline, 37" , can be longer so I can cut down. Joints are 1310.
The front passenger u-joint is toast, looks like the stub shaft is damaged too.I need to tear into it to get a better look.
I may be in that area soon to pick up my Wife's horse, May be able to stop by.
Well give me a heads up. You're more than welcome to swing by and we'll see what I can come up with. I just need a little notice so I can be sure to be around and ready to dig into these rigs. I'm going to start in on getting that top-end rebuilt 400 back in Dad's '78 real soon.
Discussion Starter #184
1 step forward and 2 steps back. Pulled the axle to replace the broken joint and found the inner axle broken at the splines and the stub shaft bent.
164257
78 Custom - 460 - NP435 - NP205 - Sniper EFI - HyperSpark Ignition - 4.56 Gears - Front/Rear Lockers
Looks like a trophy for the shelf. The 4x4 shop I occasionally go to has several broken axle ends and sector shafts sitting on a shelf.
Discussion Starter #188
I have had several trophy's like this over the years, however, this one was not my doing. I like to keep the parts I break.:cool:
Have you got a pic of the Bronco buggy around?
He really does get all it's worth out of what he's got. 🍻
