Checked the PSOM constant in my truck and it's set at 9.67 and it says I have "6" as the lockout number. Steve83 said that's what is should be for the stock 235/75R15's. Life is good! Plugged the formula's in a spreadsheet but can't come up with that constant(9.67). Life is bad.
I've checked and rechecked and verified my "circumference" number and it's within .03 of 3 different online calculators(Tire Rack etc.). My Revs Per Mile is also off by a bunch. I'm going to be replacing the tires and probably put the stockers back on. If I get a deal on a different size tire, I might grab those. I want to be able to re-program the PSOM with the correct constant. Can't do that if I can't do the "ciphering". Is their a reliable online constant calculator? My number is 2 far off and the PSOM increments are .01 and my guess is that I need to be within that tolerance. How close is close enough?
My calculated numbers:
Width 235
Aspect 75
Rim 15
Tire Height 13.8780
Total Height 28.8780
Circumference 90.7227
Revs Per Mile 698.1104 = 63,360/90.72
Coversion Con 9.43 = (698.11 x 108) / 8000
Willy.
Width 235
Aspect 75
Rim 15
Tire Height 13.8780
Willy.
