Follow this procedure EXACTLY, from the Ford TSP/PCED:
DS1 DIAGNOSTIC TROUBLE CODES (DTCS) 29 AND 452: CHECK PSOM RESISTANCE
Continuous Memory DTC 29 indicates that during the last 80 warm-up cycles, the PCM detected an error in the PSOM output signal. DTC 452 indicates the PCM detected an error in the PSOM output signal during the last 40 warm-up cycles.
Possible Causes:
-- Damaged Rear Anti-Lock Brake System (RABS).
-- Damaged PSOM.
-- Damaged harness circuits.
-- Damaged PCM.
l Key off.
l Disconnect Powertrain Control Module (PCM). Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
l Install breakout box, leave PCM disconnected.
l Measure resistance between Test Pin 3 and Test Pin 6 at the breakout box.
l Is resistance between 21,000 and 55,000 ohms?
Yes
GO to «DS4».
No
GO to «DS2».
DS2 CHECK CONTINUITY OF THE HARNESS CIRCUITS
l Key off.
l Breakout box installed, PCM disconnected.
l Disconnect PSOM.
l Measure resistance between Test Pin 3 at the breakout box and PSOM(+) circuit at the PSOM vehicle harness connector.
l Measure resistance between Test Pin 6 at the breakout box and PSOM(-) circuit at the PSOM vehicle harness connector.
l Is each resistance less than 5.0 ohms?
Yes
GO to «DS3».
No
SERVICE open circuit. REMOVE breakout box. RECONNECT all components. RERUN «Quick Test».
DS3 CHECK HARNESS CIRCUITS FOR SHORTS TO POWER AND GROUND
l Key off.
l PSOM disconnected.
l Measure resistance between Test Pin 3 and Test Pins 6, 37 and 40 at the breakout box.
l Is each resistance greater than 10,000 ohms?
Yes
GO to «DS4».
No
SERVICE short circuit. REMOVE breakout box. RECONNECT all components. RERUN «Quick Test».
DS4 CHECK RABS SENSOR RESISTANCE
l Key off.
l RABS disconnected.
l Measure the resistance of the RABS.
l Is resistance between 1300 and 1550 ohms?
Yes
GO to «DS5».
No
REPLACE the RABS. REMOVE breakout box. RECONNECT all components. RERUN «Quick Test».
DS5 CHECK PSOM OUTPUT VOLTAGE
WARNING:
THIS TEST STEP REQUIRES ANOTHER PERSON TO ACCOMPANY THE DRIVER TO MAKE MEASUREMENTS AND RECORD DATA. ALL APPLICABLE SAFETY PROCEDURES AND TRAFFIC LAWS MUST BE FOLLOWED.
l Key off.
l Breakout box installed.
l Reconnect PCM to breakout box.
l Reconnect PSOM.
l DVOM on 20 volt AC scale.
l Warm engine to operating temperature.
l Measure AC voltage between Test Pin 3 and Test Pin 6 while gradually increasing vehicle speed to 50 mph.
l Is the maximum voltage received greater than 4.0 volts?
Yes
REPLACE PCM. REMOVE breakout box. RERUN «Quick Test».
No
REMOVE breakout box. RECONNECT components. REFER to the Instrument Cluster, Speed Control or Brake Group in the Service Manual for further diagnosis.
