S
ski78
·Guest
what do i have to do to bolt a saginaw power steering pump onto my 351m in my 78?
Unless you have air or OBA, then it don't fit and/or you can't check the fluid ever again. :bangheadbmc69 said:One easy way is to just snag a Sag off of a 400 Lincoln or big Mercury..same years basically..76-80 or thereabouts.
???..the York AND the Sag Hboost pump on my EB 400 came off the same Lincoln donor..brackets and all. What you got that causes the problem, Ox?OX1 said:Unless you have air or OBA, then it don't fit and/or you can't check the fluid ever again. :banghead
Bracket I got off a late 70's T-bird. Pretty sure it was not using a york AC pump.bmc69 said:???..the York AND the Sag Hboost pump on my EB 400 came off the same Lincoln donor..brackets and all. What you got that causes the problem, Ox?
