1 - 3 of 3 Posts
1995 5.8, 2.5" Rough Country Lift, Extended RA's, 4.10's, 33" BFG's
Has anyone pumped fluid out of a E40D(or any other)tranny through the dipstick tube? I changed the fluid/filter today and the pan leaks. The filter kit came with a rubber gasket, the gasket started to squeeze out before the bolts were tight(a hair past snug)enough. I had a feeling it was going to leak and it does. I want to pump the fluid out into a clean container so I can put it back in. Would a low pressure electric fuel pump and a piece of tubing work? Thanks
J
Its obviously too late meow, but whenever I drop a pan that doesnt have a drain plug in it, I put one in... they make drain plug kits for future reference... really easy to install...
Yeah, I shoulda put in a drain plug. I thought about it but didn't do it......Damn!!
1 - 3 of 3 Posts
