21 - 34 of 34 Posts
1996 Bronco XLT 5.8L
Personally I wanted to avoid cutting the dash, but that's just me.
No cutting required with a single din unit like this. I'm installing mine in the morning. I'll post pics. Mine is 8"
Cyberslinger - 1996 XLT Sport 5.8L
Hah! 8 inches, now you’re just bragging...
Mine's 9" so hah!
Haha. Got you confused. Forgot you were the one who started the thread and had ALREADY installed a single din. Duh. My bad!
And now I will refrain from more measurement humor
Actually I won't... Yours might be a little bigger but mine has more RAM.
Discussion Starter #31
Im having trouble getting my head unit to go in far enough to lock in place. I'm going to have to try and make some room for all that wiring behind it.
Its most likely bumping up against the defroster duct. Don't push too hard or you'll break it. I did.
I called crutchfield and they said that the 90’s era Bronco has slightly less clearance for true head unit than the F150 and that’s why they say they’re not compatible. Metra makes a single din spacer that allows the headunit to stick out about a 1/4” from the dash. That solves the problem.
I do know it is tight in there. I had to get a new support cage for the head unit and now it won't lock in. Im going to work on it this weekend and it will lock by the time im done
21 - 34 of 34 Posts
