that is the best way to get them all started. also be sure to tighten both sides before you mount the frame ends. another thing to double check is that they are both level. its not hard to get them off just a tad from one another. if they arent level then you will have a leaning bronco/truckbadass1tonf100 said:lil trick next time grease the bushings and start with a longer bolt get it threaded. then one at a time remove the long bolts and replace them with the oem size and length
