yo
from 1996 Bronco Workshop Manual
Power Steering Pump Leaks
Leaking cap and dipstick or overfilled power steering oil reservoir.
CHECK for indications of false leakage � overfilled power steering oil reservoir, improperly installed, damaged or lost cap or dipstick.
Loose or damaged power steering pressure hose connections.
GO to Pinpoint Test B.
Leakage between power steering oil reservoir and power steering pump housing.
REPLACE pump as required.
Leakage at pump shaft seal area.
REPLACE shaft seal or power steering pump. REPLACE C-II pump as required
PINPOINT TEST B: PRELIMINARY INSPECTION AND LEAK TESTING
B1 PRELIMINARY CHECK
Check the power steering pump belt tension.
Check the tire air pressure.
Check power steering pump for correct model and vehicle application.
Do components check OK?
Yes Ford C-II pumps: GO to B2.
ZF pumps: GO to B3.
No ADJUST or REPLACE as required. REFER to Section 03-05.
B2 FLUID LEVEL CHECK, FORD C-II PUMP
NOTE: After any major power steering system component replacement, the system should be purged of all old fluid and replaced with new fluid.
NOTE: Fluid level may be checked when fluid is either hot or cold.
If fluid is cold (approximately 24°C [75°F]), use cold full mark on dipstick.
If fluid is hot (approximately 77°C [177°F]), use hot full mark on dipstick.
Is fluid level correct without any signs of air bubbles in fluid?
Yes GO to B5.
No ADD Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F. Do not overfill the reservoir. GO to B4 for bleed procedure if bubbles are still present.
B3 FLUID LEVEL CHECK, ZF PUMP
NOTE: After any major power steering system component replacement, the old fluid should be purged and replaced with new fluid.
Key off.
Remove the power steering pump oil reservoir filler cap and check the level on the dipstick. Use the cold mark if fluid is at room temperature (20°C [70°F]). Use the hot marking if the fluid is at normal operating temperature (80°C [175°F]).
Is the fluid level correct without any signs of air bubbles in fluid?
Yes GO to B6.
No ADD MERCON-II® or equivalent. DO NOT OVERFILL the reservoir. GO to B4 for bleed procedure if bubbles are present.
B4 BLEED AIR FROM SYSTEM
Fill power steering oil reservoir.
Operate engine until it reaches normal operating temperature.
Turn steering wheel to the left and right several times without hitting stops.
Recheck fluid level inpower steering oil reservoir and fill if required.
Are air bubbles still present in fluid?
Yes PURGE air from system. REFER to Purging Power Steering System of Air in the Service Procedures portion of this section.
No ZF pumps: GO to B6. Ford C-II pumps: GO to B5.
B5 EXTERNAL LEAK CHECK
Key off.
Wipe off power steering pump, power steering pressure hose, power steering return hose andsteering gear.
Key on, engine running.
CAUTION: Do not hold the steering wheel in the far left or right position, or damage to the power steering pump may result.
Turn the steering wheel from stop to stop several times.
Can leak location be detected?
Yes REPLACE pump.
No REFER to External Leakage in the Service Procedures portion of this section. SEE Fluid Leak below
B6 EXTERNAL LEAK CHECK, ROSS STEERING GEAR AND ZF PUMP
Key off.
Wipe off power steering pressure hoses, power steering return hose, steering gear and power steering oil reservoir.
Mix one teaspoon of oil-soluble aniline dye intopower steering oil reservoir and fillpower steering oil reservoir to specifications as required.
Key on, engine running at 1000-1500 rpm.
Turn steering wheel all the way to the left and right several times.
CAUTION: Do not hold steering wheel in the far left or right position, or damage to power steering pump may result.
Key off.
Do reservoir or outlets leak?
Yes CHECK power steering return line clamp for proper installation and reservoir ports for cracks. SERVICE or REPLACE as required. GO to B7.
No If power steering pump oil reservoir filler cap or dipstick leaks, CHECK power steering pump oil reservoir filler cap for good seal and tight fit. REPLACE if damaged or broken. GO to B7.
B7 FITTINGS AND O-RING LEAK INSPECTION
Clean the outside of the steering gear, the bottom surface of the power steering pump, and all lines and fittings.
CAUTION: Do not tighten the fittings with a standard open-end wrench.
Tighten all fittings using a flare-nut wrench.
Do tube seats leak?
Yes REPLACE tube seat.
No System OK.
Fluid Leak CAUTION: Do not hold steering wheel (3600) in the far left or right position, or damage to power steering pump (3A674) may result.
With engine idling, turn steering wheel left to right several times from stop to stop. Check all possible leakage points.
Tighten all loose fittings. Replace damaged lines and seals.
NOTE: For repair and replacement procedures in the following chart, refer to Section 11-02B.
Leakage Areas, Power Steering Pump Oil Reservoir Filler Cap and Connection, Ford C-II Pump; see diagram below
Note: Use of a tapered shaft may be required to stretch Teflon® washer to allow for installation onto tube nut.
Leak Category Required Service
1. Rotor shaft sea;l Replace pump.
2. Reservoir O-ring seal; Replace pump.
3. Power steering return hose; Reposition or replace power steering return line clamp.
4. Power steering pump valve outlet fitting; Tighten power steering pump valve outlet fitting 35-54 Nm (26-40 lb-ft). If leak continues, replace pump.
5. Hose tube nut; Tighten pressure hose tube nut to 41-54 Nm (30-40 lb-ft).
If leak continues, remove tube nut and inspect Teflon® washer. Replace if required.
If leak is due to pressure hose assembly O-ring, replace hose assembly.
6. Power steering pump oil reservoir filler cap; Check for damaged or missingpower steering pump oil reservoir filler cap or dipstick. Check oil level, and correct as required. If leak continues, replace pump.
