1 - 3 of 3 Posts
Seems to be just coil spacers for the front. People do use those.. (which I'm about to get some because my wife's bronco is sitting nose low) AAL's in the rear rather then blocks is better..
All in all it's ok if you just want a 2" lift.. Don't know why you would only go 2" I like to go as big as possible, but that's me.. We're all diferent. :)
might look into why it is saggen. you might find a worn part. if you change the front too much you will need drop mounts or might run into alignment issues. might look at everything real close then decide to make the change...mike
1 - 3 of 3 Posts
