Administrator
Thinking of doing the swap to f250-350 booster and m/c...been reading thru the swaps that have been done just have a few questions for those that might have done the swap already...
1. Did you use similair year equipment ie (1985 bronco-1985 f250)
2. if so my vendor tells me he has a listing for 2 dif. size boosters one is a 9" and the other is 11"...which would you recommend.
thanks for any imput...
Tim.
I just got my hydro booster and going to get the other needed parts and go that rout. It has more clamping force and uses less space and does not require any vaccum source. I will to a tech string as i get closer...mike
Administrator
Dat_Bronco_Boi said:
i did the 11 inch booster swap from a 85 f250 i need to upgrade everything else buti can tell a difference
thanks that's the info I was looking for.:rockon
I got rid of the booster from my 1984 F250,because the early to mid 80's boosters don't have the boost that the mid 90's boosters have.I put a booster from a 1995 F250/350 on my truck,Works awsome,I had even tried a reman booster for the 1984 F250,it still didn't work any where near as good as the 1995 booster.
