After reading the "All you ever wanted to know about lifts" thread and looking into several posts and lift companies I think Im going to go with an 8" Skyjacker lift. But Ive read several times that a lift that high causes all kinds of problems and that the TTB and 8.8 cant handle 39.5 tires, which is what I want to run. Are the 39.5s too much for the TTB and 8.8 only if you wheel hard or there just too much regardless? Can they survive on a daily driver for awhile? I see "Blaze" has a setup similiar to what I want and he seems to be fine but others have all kinds of trouble. Assuming I get the lift done right with all the necessary accesories will I still be screwed? If I plan on going SAS will getting this lift be a waste of time? Is it possible to fit 39.5s on a 6" lift without using a body lift? I like the BDS (although no one sells it hardly) and the Dick Cepek but from what Ive read only an 8" lift on my 1996 Bronco will allow 39.5s. What kind of problems can i expect with this (other then loss of power until I regear the rear)?
