1 - 8 of 8 Posts
what yrs did they put the independent suspension on f250? i wanna get a diesel with a solid axle like 93 or newer....
Stuck like a MoFo
all f250's after 80 had IFS, you would have to wait until they came out with the revised body in '99 the actual Superduty's to get a solid D50
We have a few 92-97 f-350s at work with solid front axle's.
i was reading and it says they went back to solid axles in 97 the last yr of the 93-97 body style... aren't they d60 not d50? i wanna do liek an 8 inch susp lift adn you can;t unless its solid axle...
If you want the D60 in the '92-'97 bodystyle, just buy the F350, none of the F250's from those years came with a solid axle, (not even the '97). My '94 F250 had the D50 TTB, so I had to swap the axle out with an F350 front axle assembly to get the "monobeam" D60.
TTB for short
ditto
Stuck like a MoFo
Dustin said:
the superdutys all have solid axles
Did the early superduties have solids? The dealer changed ones in the 92-98 style. I know some that were modfied had a goofy 60 or somethin that was a PITA to get steering parts for
1 - 8 of 8 Posts
