89 F350 EFI 460 ZF-5.
Finished up the rebuild on this and it's not getting fuel. All the electronics work, tach, dash lights, elec fan, horn haha. In tank fuel pump may or may not be turning on but the high pressure in line pump is definitely not turning on.
Pump is new, and when I put 12v positive directly to the pump it spins fine, but nothing with the key. So if the pump is good that means the relay is toast right? or is there another place I should be looking?
Edit: I have checked the inertia switch and that's not the problem.
yeah, check your relay. You might be able to just pull another one and put it in it's spot to see if it'll go....
yep it was the relay. I guess the winter rain/snow killed it.
:thumbup
Glad you got good advice. See people suggest too many "big" issues before they check the simple ones. Glad you got it fixed. Good advice goober.
