1 - 17 of 17 Posts
is there suck a thing as a quick release kit for the rear top of my 86 bronco???. or is it just simply unbolting 30 or 40 bolts,. ive never done this job & just had a look , do i have to take off a lot of interior trimming to undo the bolts. How long from start to finish would anyone know how long it takes to pull one off. ?? since i cant get a soft top in australia, could it be done on a saturday morning & put back on on a sunday arvo, or is it too much of a job to do that a lot.???
I took all the bolts out and lifted mine up in about 6-8 minutes. I don't have the interior trim, but it can't take that much longer I don't think.
I can get the top off with trim and up on the rack in about 15 minutes.
Power tools help.
Designated Tranny Killer
its more like 15-20 bolts, not 40
I can have the hard top off in 10 minutes and put it on in 25
Back in Action
u need a t40 tamper proof torx bit for the bolts. 14 IIRC. and a t50 for the seat belts
took me like 3hrs to find a place that carried those torx bits
i take my top off all the time, sometimes i put it back on that day. just grab a friend to help
He has an 86, no shoulder harness seat belts.
Shouldn't need any "torx" bits.
Engineer
I only put 6 of the bolts in mine and I replaced them with hex bolts not tamper proof torx heads
Should only need an 8mm socket for the top and a #2 phillips head screwdriver for the trim on an 86, at least that is what my 86 has.
Discussion Starter #15
Does that mean the rubber comes off & stays with the roof, or is it a separate piece. im worried that if its never been taken off, will the rubber seal fall apart in my hands. are they a thick ass rubber that i dont need to worry about
Remember in order to get that bolt really tight--------STRIP IT...., THEN BACK IT OFF 2 TURNS....
excellent, ill go chasin Kangaroo's with the top off this weekend....
that sounds awesome...
they are thick, you dont have to worry about it falling apart. You take it off with the top
1 - 17 of 17 Posts
