Installing the new radiator support and I'm using the prothane body mount kit. There are a set of bushings just for the radiator support and I know others have used them but I can't see pictures because threads are too old.
Question is, what original hardware did you use with the mounts?
Pictures are what I plan on using, but missing shims.
TIA
I used everything you show there. I was able to salvage the mounts as well.
I think the rad support bushings are the worst out of the bunch. I could never get them to tighten up to the point I was satisfied. I bought the Energy kit, and wasn’t wowed. Just not many other options.
I did. I went back with everything as it came out. I replaced bushings when I removed the body lift PO installed.
I wouldn’t see why you couldn’t use washers instead of shims. The factory shims must be slid over the 12mm bolt. They can’t be removed with the bolt in place. So the work to change them is the same.
