Yo Bud,
Do you have the OEM Base, or cassette or
Compact Disc Radio?:
STATION RECALL MEMORY TEST
- Press SEEK or TUNE buttons to a desired station.
- Press and hold one of the (1 through 5) memory buttons for two seconds until station sound is returned (repeat for all five buttons).
- Do for AM, FM1 and FM2 bands using 15 stations.
- Turn radio chassis off, then on.
- Press each station recall button and verify memory storage.
Is memory test successful?
Yes | No |
GO to A9. | REMOVE radio chassis for service. |
A9 VOLUME CONTROL TEST
- Press VOLUME (+) and (-) to verify an increase and decrease in volume sound from radio chassis.
Does volume change properly?
Yes | No |
GO to A10. | CHECK radio speakers and connections. REFER to Symptom Chart if diagnosis finds radio speakers inoperative. REPEAT volume test. If volume still inoperative, REMOVE radio chassis for service. |
A10 TUNE CONTROL TEST (ESR)
- Press TUNE button (>) or (<) to change the frequency station up or down one increment at a time. Change frequencies quickly by holding the (>) or (<) side of button. Verify for all bands.
Does TUNE operate properly?
Yes | No |
GO to A11. | REMOVE radio chassis for service. |
A11 TUNE ANTENNA TEST (OPTIONAL)
- Tune radio on AM band outside of building.
- Press SEEK to observe all listenable stations on band. Count number that can be tuned.
- Compare to a vehicle with known good radio chassis.
Are normal number of stations received?
Yes | No |
GO to A12. | If an absolute number of stations cannot be tuned, PERFORM radio antenna component test. REFER to Components Tests in this section. If antenna operative, REMOVE radio chassis for service. |
A12 CLOCK — CONTROL TEST
- Press CLOCK button and simultaneously press SEEK (>) to advance hours or SEEK (<) to advance minutes. Release CLOCK button.
Does CLOCK operate properly?
Yes | No |
GO to A13. | REMOVE radio chassis for service. |
A13 TONE CONTROL TEST
- BASS: Press AUDIO button repeatedly until BASS is displayed. Press VOLUME (+) to increase low frequency sounds and VOLUME (-) to decrease low frequency sounds.
- TREBLE: Press AUDIO button repeatedly until TREB is displayed. Press VOLUME (+) to increase high frequency sounds and VOLUME (-) to decrease high frequency sounds.
- Verify proper display and sounds for each tone control.
Do BASS and TREBLE operate properly?
Yes | No |
GO to A14. | CHECK radio speakers and connections. REFER to Symptom Chart if diagnosis finds radio speakers inoperative. If BASS and/or TREBLE still inoperative, REMOVE radio chassis for service. |
A14 BALANCE CONTROL TEST
- BALANCE: Press AUDIO button repeatedly until BAL is displayed. Press VOLUME (+) to shift sound to right radio speakers and VOLUME (-) to shift sound to left radio speakers.
- Verify proper display and sound in proper radio speakers.
Does BALANCE operate properly?
Yes | No |
GO to A15. | CHECK radio speakers and connections. REFER to Symptom Chart if diagnosis finds radio speakers inoperative. If BALANCE still inoperative, REMOVE radio chassis for service. |
A15 FADER CONTROL TEST
- FADER: Press AUDIO button repeatedly until FADE is displayed. Press VOLUME (+) to shift sound to rear radio speakers and VOLUME (-) to shift sound to front radio speakers.
Does FADER operate properly?
Yes | No |
REFER to symptom chart to determine if an inoperative condition exists. | CHECK radio speakers and connections. REFER to Symptom Chart if diagnosis finds radio speakers inoperative. If FADER still inoperative, REMOVE radio chassis for service. |
A16 CHECK INOPERATIVE OR INTERMITTENT
- Verify if condition is intermittent or inoperative.
Is condition intermittent?
A17 CHECK FUSE
- Key off.
- Check fuse 11 (15A) in instrument panel fuse panel.
- Check fuse 17 (50A) in power distribution box.
Are fuses open?
Yes | No |
REMOVE open fuse and GO to A18. | GO to A19. |
A18 CHECK FOR GROUNDED POWER FEED
- Key off, check Circuit 137 (Y/BK) at radio chassis connector C1 for a short to ground.
Is power feed grounded?
Yes | No |
LOCATE short to ground and REPLACE or SERVICE. REPLACE fuse(s). RETEST system. | REPLACE fuse and RETEST system. If fuse still opens, REMOVE radio chassis for service. |
A19 CHECK POWER FEED
- Connect digital volt-ohmmeter between radio chassis connector C1 Circuit 137 (Y/BK) and known good ground.
- Key to RUN or ACCESSORY.
Does digital volt-ohmmeter indicate 10 volts or more?
A20 CHECK WIRING CONTINUITY — FUSE TO RADIO
- Remove fuse 17 (50A) temporarily.
- Check continuity between fuse 17 output cavity and radio chassis connector C1 Circuit 137 (Y/BK).
Is continuity present?
Yes | No |
GO to A21. | SERVICE wiring as required. RETEST system. |
A21 CHECK WIRING CONTINUITY — FUSE TO IGNITION SWITCH
- Check continuity between fuse 11 (15A) input cavity and ignition switch Circuit 297 (BK/LG).
Yes | No |
RECONNECT fuse and GO to A22. | SERVICE wiring as required. RETEST system. |
A22 CHECK IGNITION SWITCH POWER
- Connect digital volt-ohmmeter between ignition switch connector Circuit 297 (BK/LG).
Yes | No |
REMOVE radio chassis for service. | SERVICE ignition switch, fuse P (50A), or Circuit 37 (Y) for open. REFER to Section 14-00. |
A23 CHECK RADIO SPEAKERS
- With radio chassis operating, check if condition is on all radio speakers.
Is condition present on all radio speakers?
A24 CHECK RADIO ANTENNA
- Check radio antenna, cable connections and wiring.
Is antenna system operating properly?
Yes | No |
GO to A25. | CONNECT, SERVICE or REPLACE antenna components as required. RETEST system. |
A25 CHECK RADIO CHASSIS
- Substitute known good radio speakers to radio chassis.
- Verify if condition is in radio speaker or radio chassis operation.
Is radio chassis operating?
Yes | No |
CONNECT, SERVICE or REPLACE radio speakers and wiring as required. RETEST system. | REMOVE radio chassis for service. |
PINPOINT TEST B: RADIO CHASSIS DISPLAY BLANK — RADIO CHASSIS OPERATES
B1 CHECK OPERATION OF RADIO CHASSIS
- Press radio POWER on.
Isradio chassis display lit?
B2 CHECK QUALITY SOUND FROM RADIO SPEAKERS
- Verify that quality sound is coming from radio speakers.
Is quality sound coming from radio speakers?
Yes | No |
DISCONNECT fuse 11 (15A) and GO to B3. | GO to A1. |
B3 CHECK WIRING CONNECTIONS
- Check wiring connectors and wires for damage, corrosion or open wire at radio chassis connector C1 Pin 6, Circuit 137 (Y/BK).
Are wires and connections OK?
Yes | No |
RECONNECT fuse and GO to B4. | SERVICE harness, connector and wiring as required. RETEST system. |
