1 - 10 of 10 Posts
i was driving today and my radio just quit working, ive checked the connections but cant seem to fiond the problem can anyone help
thanks
Had the same problem,ended up being a blown fuse,replaced it and walla it worked again.
If the radio fuse is intact, pull out the unit and test to see if you have 12v on the yellow radio lead. If so, turn the key "on" and check to see if the red lead gives you 12v. If so, check to see that your ground wire is intact. If that all checks out, then I think you have a bad radio.
Eamon
1 - 10 of 10 Posts
