So here is what I have been working on with my 60 swap. This actually took a lot of work. that is 3/4" by 3" plate and was a pita to drill and cut thru. Both the spacer and lower plate are made of it. the 7/16's bolts are recessed to hold the lower reatainer plate to the radius arms, and the 5/8 bolt is recessed from the underside and then welded in to hold the lower retainer. I netted about 2" lift over the stock 79 lower reatainers, and i sits WAY better with the ttb bracket than the 79 stuff.
Thanks again to Bill (chevyboat) for all the help. Oh, thanks to Chris85 also for being the originator of this idea.
there are lots of pics on my superford site of the how and whats up if you are interested. If not, piss off
the spacer installed
lower bracket
lower bracket installed
everything together
lower bracket
everything together
