I have a 78 bronco that needs new or shall I say straight radius arms. What year models will interchange with mine?
Got quad shocks??I have a 78 bronco that needs new or shall I say straight radius arms. What year models will interchange with mine?
Yes but I just run singles on the front.Got quad shocks??
There is a guy on eBay that is selling early bronco radius arms stating that they will fit on the 78-79 bronco, is this true?77.5 -79 F-150 or 78-79 Bronco is a direct swap.
So the lenghts are the same?the bolt spacing for the spring cups is different
EB arms are the same with the exception of the spring cup holes, but you MUST use EB caps and arms as a matched pair, they are different. You can either use the EB spring cups, or drill out your FS cups to match.I have a 78 bronco that needs new or shall I say straight radius arms. What year models will interchange with mine?
