1 - 8 of 8 Posts
Has anyone ever seen factory high clearance brackets. I looked under my freinds 77 f150 high boy. They are like tucked up into the cross member and look like they would be nice with my arm extensions. I know these are factory because the guy bought the truck new and only put a 2" suspension lift on it with 35x14.50's on it. The thing sits as high as my bronco. If anyone knew where to get these that would be great.
o[|||]o
Some pics would help if you can get any.
Never thought of the two wheel drive trucks. I will try to get some pics of these here in the next couple days.
BrokeCuzWheelin said:
You mean a mount like this? -
(note - the mount is moved back farther on frame in pic cause I was mocking up the extended radius arms for the first time)
Those are the '77 and earlier 1/2 ton 4x4 radius arm mounts.
And your friends truck isn't a high-boy, it's just an F-150. High-boys are pre-mid '77 F-250s.
Ha thanks for that pic and info.
CJW said:
My friend and another guy I know have high boys that are f-150's.
They aren't "High-Boys" They are just F-150s
High-Boys are 67-77.5 F-250 4x4s. They have divorced t-cases. They are not "lifted" from the factory, but they do sit higher than most stock trucks did. All 67-77.5 F-250 4x4s were "High-Boys". I have seen these facts I have stated and them some many times on the internet, in books and magazines, and also heard it from several Ford Truck collectors. One thing I am actually not sure of, though, is where the "High-Boy" name came from since as I sit here paging through a 1970 Ford Pickups brochure I do not see the name "High-Boy" used at all.
Here's a link to a thread where somebody else states basically everything I just did and if you search around the internet long enough you will find the same facts repeated on other Ford truck sites.
http://www.ford-trucks.com/forums/archive/index.php/t-387758-Highboy%3F
1 - 8 of 8 Posts
