1 - 3 of 3 Posts
Do you mean the bushings that adjust the caster/camber at the ball joint? I never heard of a radius arm bushing described on degrees.
Sway's jealous of my
He's talking about the C-bushings that go between the wedge and the radius arm at the axle on the radius arm. There's also the radius arm pivot bushing at the frame. The reason or the different degrees is so that as you lift it, you can offset it to maintain your caster at the proper (close to stock) setting. This is alleviated as ewll by dropping the mount as well as extending the radius arms. Some arms (Cage, Duff) come with caster built in.
1 - 3 of 3 Posts
