They are different. I just layed two side by side. One had the threaded end on the right side and 'C' on the left. The other was opposite. I turned both around and still got the same result.Hmm, thought i looked at two off the truck and they were different.
What happens if you swap "C" caps? You get a left and a right then?They are different. I just layed two side by side. One had the threaded end on the right side and 'C' on the left. The other was opposite. I turned both around and still got the same result.
.:toothless
If you would get a torch & cut the threaded doo dad off they will be the same.They are different. I just layed two side by side. One had the threaded end on the right side and 'C' on the left. The other was opposite. I turned both around and still got the same result.
.:toothless
