hey i got a question about mounting my extended radius arms. i got the extentions from stonecrusher and i have the arms boxed and welded up but as far as mounting them to the frame with the heim does anyone make pre made brackets or do i have to custom make them. thanks
Some assembly required!
Cage makes some of the nicest radius arm brackets I've seen, but WOW are they expensive. Over $100 a side last time I asked about it for the new style ones, which is why I'm just going to make a bolt in box for the frame and use my old style Cage brackets. With that said though, their quality is second to none, so if you've got more money than time you can't go wrong with buying Cage.
1996 Bronco 5.8l E40D(soon to be ZF) 4:56 and 35s
I think when you extend the stock arms they sit inboard of the frame. I am going to extend and box my arms, then make a new trans crossmember and atach arms to new member.
