· Surrounded by Assholes
Mechanic says the steering shaft has play in it. I grabbed the steering shaft and can jiggle it a bit. So I am assuming my rag-joint is bad. Is it located under the torn-up rubber boot at the top of the shaft by the firewall, or at the bottom next to the pump?
If you check out the Borgson web site they sell them for your truck there.
Unfortunately Borgson wont be around friday to sell me one so I can replace it saturday along with my timing/chain and core support. Napa will. Will the rubber style from a 90's Bronco work?
