1 - 3 of 3 Posts
so I have a 90 5.8 bronco....drives wonderful smooth for a 30 year vehicle, ive replaced every sensor...everything but the actual motor block and transmission...no check engine lights ill just be driving down the road and it shuts off no sputter or anything just on/off it starts right back up instantly but what would be causeing this?
Yo northern1,
Possible codes are DTC 14 & 18; Profile Ignition Pickup (PIP) ;
Troubleshooting; "...The top three leads (for PIP signal) can lose continuity with the back plate (ground) on the module when the unit is hot. You should consider a remote mounted TFI. If your TFI is failing from heat, it can give off computer codes 14 (PIP) and 18 (SPOUT). stalling/dieing or sputtering when hot but runs when it cools off. This can be caused by a faulty TFI and the biggest culprits are heat. Another culprit can be a wire grounding out. Problematic TFI's can give off codes 14 (PIP) and 18 (SPOUT)..."
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19 @
Code Reader.....
1 - 3 of 3 Posts
