Hi,
I am to the point of either going with the AutoFab or Camburg beams and extended radius arms on the Bronco. I have worked on TTB trucks for over 20 years and have seen problems with most lifts and want something that is going handle the road as good as a tight (not all worn-out) stock set-up. With the angle of the steering is there any bump-steer problems at hi-way speeds? I am assuming the radius arms are designed for at least 4 degrees of caster with there recommended springs.
The main use for the Bronco is more daily driver and 1 or 2 trips to the dunes a year. I figure on just the basic system with stock spring buckets and Bilstein 5100's. I am also running the stock wheels with 33x12.50 Goodyear Silent Armors. Still figuring out what to do on the rear. Thanks.
