when i step on the gas or lay on the brakes the rear axle seems(sounds)(feels)to move.whats the cause?and how do i fix?any help would be great
Are you sure it is the rear? I had the same problem on mine thought it was the rear it wound up being bad radius arm bushings. Just food for thought. If it isnt r/a bushings definitely check everything in the rear previously mentioned by 75F350 .when i step on the gas or lay on the brakes the rear axle seems(sounds)(feels)to move.whats the cause?and how do i fix?any help would be great
