OK posting here in new thread. I posted some questinons in the newbie flame free thread (post3522). Most of the questions I posted there have been answered, thanks to you guys for that! I do have some follow up questions and potential axles I'd like some help with at the bottom of this msg.
D60 rear questions/thoughts:
looking to build up a rear axle for semi DD no larger than 35 tires. mild/moderate wheeling on the weekends. First time with rear ends.
I am considering the D60 for the following reasons:
*full float so if axle breaks, no big deal, can still get home
*Ox locker to be added later on
*cheap. or so I have read, but seen no proof as of yet
*I really wouldn't mind building another 9", but main drawback is no ox locker.
Reasons I'm wanting OX lockers:
*Don't want to mess with air/ARBs. too expensive and if it's complicated, I know i can mess it up somehow.
*Reading stories about detroit lockers have me paranoid, although I've never ridden in a vehicle with one to see first hand how it drives and can loose the rear.
*Lunchbox lockers seem to be on the verge of overworked with 33's/35's and I think the locker in the rear of a DD thing still applies. (Dont think this statment is accurate, as the lunchbox lockers seem to be OK with these tires and is more dependent on the carrier it is in D44 locker will be weaker than D60 locker ect...)
*I do like the idea of being able to select when fully locked or fully open
More thoughts/considerations:
*Ox locker for 8.8 available, but this just seems like a downgrade especially considering they aren't full float.
*No ox locker for the sterling 10.5 either.
*corp 14 bolt seems a bit of overkill, again, no ox
* would also consider an electric locker, but I don't think they are avail for the 9" either
* would probably leave the D44 up front for now and just switch to 8 lug outers, or more realisticly just carry 2 spares around for a while
* would be a project build up, not somthing I need to have completed right away
* budget minded-who am I kidding I like to pinch pennies til lincolns eyes pop out...
Also, I'll note here that I just went to get an alignment on the front stock D44 (which i just swapped earlier this year from the parts truck) and they said I need new ball joints. Only $100 for parts and $1200 for labor. My immediate reactions were:barf & :cry.... They also said they estimated about 6 hours work which = $200/hr! But... I just talked to my mechanic friend and he said he would help me with whatever and has all the tools experience, so that ROCKS!
Anyway I want to keep the D44 front but have the wheels/hubs to match the full floating rear. Since I will do new ball joints anyway, what parts should I go with on the front when redoing the ball joints. Both the front and rear upgrades are not immediately needed and will be a work in progress. I plan do ride rig as is until spring, but need something to work on in the meantime...
Will post pics of potential axles soon...
