I have used a similar kit in the past on another project, but it was for a car. You don't always get what's in the picture either. I ordered a front disc brake conversion kit for my mustang i had, it came with adapter plates and calipers off an 80's S-10...did it work? Yes but it wasn't what the kit stated or showed in the picture, then i read the fine print that stated the fact that "kits vary". The really janky thing about that kit that bugged me most was it came with one of those needle valve type proportioning valves, so i had to plumb that inline and get it adjusted properly.
I agree with the consensus, the drums are A-O-K in fact they probably stop better than those small discs, you get a lot of surface contact. I will state that the only benefit that you probably wouldn't even be able to notice is that you'd have less drag with the disc brakes as drums always have that slight bit of contact at all times.
