1 - 4 of 4 Posts
Quick question...does a rear driveshaft from a 79 Bronco fit on a 91 Bronco? Thanks
Ford Hoarder
78 & 92
it will not just bolt in. The issue is that the 91 uses flanges and the 78/79 trucks use yokes.
You maybe able to work around this issue.
Also the length is likely incorrect due to most 78/79 will not have the same engine and trans as the 91. As such the 79 could also be 1310 instead of the bigger 1330, though that was a switch over year, so depends on exact date of manufacture. Best to check.
1 - 4 of 4 Posts
