1 - 1 of 1 Posts
Finally finished installing a new rear window in the pea green beast and basically rebuilding the tailgate. :whiteflag I had no idea how difficult those little chards of glass would be to remove from inside of the tailgate. Hell, I should have simply removed the whole tailgate to begin with and save myself some time:
-Replaced inner/outer tailgate weatherstripping and the large piece inside to the top.
-Replaced all of the rusty hardware and installed the swing away tire carrier support bracket that fits inside of the tailgate and drilled/mounted the clasp.
-Cleaned every piece of *&*^%& glass out of the tailgate.
-Replaced the (s) tailgate support cables.
-Washed out the bottom portion of the tailgate and coated it w/Corrosion X.
-My hats off to Steve83, his expertise and links were invaluable. Spent way more time on the assend of my Bronco than I had planned. Maybe now I can clean out the engine compartment and replace the plugs & wires. Whew!
1 - 1 of 1 Posts
