aka: kemicalburns
I have a pair of Pro Comp Leaf springs that are missing the degree shim. I need a pair to get the proper angle. Not sure what degree these should be otherwise I would just buy a set online. Much appreciated
Charlie don't surf..
'92 Ford Bronco XLT
not sure if it's any help, but I'm running the factory shims on mine with the 6 inch spring and it's fine.
Ford Hoarder
78 & 92
Also ran the above setup on my 92 before I put 4" lift in front. Now I run without the stock shim and a re-indexed axle.
aka: kemicalburns
I have the stock rear degree block in place but for some reason the pinion still isn't point directly at the Tcase/cardion joint. I have a vibration due to this which I attribute to the shim being gone.
My springs are the 4" lift springs so that part number might not be accurate.
