1 - 4 of 4 Posts
What is the best motor for my 79 tailgate window. Ours is lifting and lowing slow. Thanks
How slowly? Make sure the felt tracks aren't catching up on the window and that the wires aren't corroded. If it rolls up and down then it's probably not the motor but something else binding it up
Yo mickinok,
WELCOME!
As canuckistan97 advised.
Inspect glass weatherstrip for grime, lack of lubrication. Clean ws with water/Dawn mixture, then clean water.
Ford recommends, "Use Silicone Lubricant C0AZ-19553-AA (jelly) or D7AZ-19553-AA (spray) or equivalent meeting Ford specification ESR-M13P4-A on the door and window weatherstrips whenever necessary. Silicone lubricant helps avoid weatherstrip squeaks and retards excess weatherstrip wear from chafing between the glass and the weatherstrip. It also helps to retain glass alignment by reducing friction between the glass frame and the rubber weatherstrip.
miesk5 note, test the silicone on a regular styrofoam cup first; if the cup gets funky or melts, then the can or tube contans oil, a regular occurrence now, esp if from China.
Use Multi-Purpose Grease or equivalent meeting Ford specifications ESR-M1C159-A and ESB-M1C106-B to lubricate door and tailgate hinges. Apply an even coat to all hinge pivot points as outlined in the maintenance schedules or when a binding or squeaking condition occurs..." I bought a can of Motorcraft Multi-Purpose Grease @ Advance Auto a few years ago, or use Valvoline mp grease
I use DuPont™ Non-Stick Dry Film Lubricant with Teflon™ on the flocked weatherstrip edges that hug the glass.
"Take off the TG access cover and spray Tri-Flow in the tracks on either side so the regulator toggles slide up and down easy" by our late friend here JKossarides.
"The best grease for the slides & tracks is PTFE". by Steve
Is window regulator rusted badly? If so, clean & lube it with multi purpose grease.
Are Glass "rollers" ok?
161765
Tailgate Regulator Glass Roller Replacement @ Replacing the swivel slide and rear window by Bronco-In-Training
Ensure that the motor is mounted properly to the back of the regulator.
Tailgate could be mis-aligned. Inspect gaps between each side of the tailgate and the quarter panels. If the tailgate is too high or low, the latch jaws will cut into the striker bushings, so inspect them.
See 78-79 Tailgate Striker Bolt Revision @ Tailgate Striker bolt - FSB Forums
Tailgate and some other parts are available @;
Bronco Graveyard, a FSB VENDOR! @ Tailgate Bronco-Broncograveyard.com ( tailgate section
Rock Auto. A FSB VENDOR! @ RockAuto
Auto Krafters - Bronco/Ford truck parts & accessories @ 1995 Ford Bronco Parts Ford Parts, Classic Car Parts, Truck Parts and Services by Auto Krafters-Mustang Auto Parts Too!
Mill Supply - Bronco/Ford truck body panels, interior door panels, weatherstrip, mirrors, headlights, tail lights, side marker; Click Order a CATALOG
@ Mill Supply | Snow Plow Parts - Stepvan Parts - Rust Repair Panels | Mill Supply, Inc.
National Parts Depot - Bronco/Ford truck parts & accessories; Click Order your Printed NPD catalog
@ National Parts Depot | Restoring American History | Mustang Parts | Camaro Parts | Chevelle Parts | Ford Truck Parts | T-Bird Parts | Firebird Parts | Chevy Truck Parts
CARID A FSB VENDOR @"CARiD.com - Auto Parts & Accessories | Car, Truck, SUV, Jeep
LMC TRUCK® (Long Motor Corporation) - Bronco/Ford truck parts & accessories & 66-77 & 80-96 Bronco
Truck Parts & Truck Accessories @ Search | com.com
Galpin Ford @ Galpin Ford
Parts Geek has Motorcraft @ Discount Auto Parts Online -- PartsGeek.com - Domestic & Import Car Parts Warehouse
Metro Moulded Parts - rubber restoration parts & Bronco/Ford truck weather stripping; Click Free Catalog
@ Metro Moulded Parts ~ Top Quality Automotive Weatherstripping and Rubber Parts
SoffSeal® (formerly A&M Soffseal) - Bronco/Ford truck door & window weather stripping; Click Free Catalog @ SoffSeal | Classic Car Weatherstripping Manufacturer
Steele Rubber Products - Bronco/Ford truck weather stripping & rubber; Click REQUEST A CATALOG @ Automotive Rubber Parts and Weatherstripping
78-79 Broncos
by bwautoparts.com
REMOVABLE ROOF PANEL SEALS Diagrams, 78-96 w/Ford part numbers;
D8TZ-9851322-A Removable Roof Front Seal On fiberglass roof;
D8TZ-98513C22-PR Removable Roof Side Panel Seals on 78-79;
D8TZ-9854732-A Front Roof Rear Seal on metal roof on 78-79;
E1TZ-98422A20-A Back Window Glass Lower Side Run, RH or LH on 78-96
Roof Rail Seal ATTACHES TO THE REAR OF THE METAL CAB 78-79
Part #: D8TZ-9854732-A
$40.95
Source: by bwautoparts.com via web.archive.org
Bronco Catalog 2003
Camper Top Location Diagram #1; "...There's 1 weatherstrip across the back of the cab that slips onto a lip of steel, and a reinforced rubber trim that covers another lip, but it doesn't seal anything. Then there's a foam rubber gasket glued under each side of the shell, terminating in a large foam block at the tailgate. So that's a total of 4 pieces, but only 3 are seals. Only the weatherstrip on the cab is marked in the 1st diagram, but all are shown in cross-section..."
http://www.supermotors.net/registry/media/282490
by Steve83 (Steve, That dirty old truck) at SuperMotors.net
Camper Top Location Diagram #2 http://www.supermotors.net/registry/media/282491
by Steve83
Weather Seal, Outer, Rear Glass Run Seal Removal (broncograveyard pn 34543 for 80-96); "...Use a screwdriver to gently pry the OUTER weatherbelt up just enough to pop the cllps loose. I've pulled the far end out to show the clips, but it should be left straight until ALL the clips are loose, then lifted out without bending. The inner seal is removed the same way, but use a rag between the screwdriver and the paint..."
Source: Steve83 (Steve, That dirty old truck) at SuperMotors.net
Weather Seal, Camper Top Weather Seal, Glass Run Info & Ford pn; "...Some aftermarket versions are simply a continuous strip - they lack the formed corner pieces at each end..."
Weather Seal, Threshhold in 78-96 Diagram; "...the body style shown is '78-79 (taillight & strike mounting) and the actual threshhold is NOT shown. But the seal & retainer are the same for '78-96. The 56928-S55 screws are phillips head with large integral washer ~1/4" long with self-drilling tip.The 55933-S55 screws are countersunk oval phillips head ~1/4" long with normal tip..."
Weather Seal Parts Break-Out Diagram; "...The outside weatherbelt that wipes the glass is D8TZ-9841610-A and cost $24 in 1996. The inner (9841676 above) is F6TZ-9842072-AA and was $27.
To assist you, here is:
Ford 1979 Bronco/F Series Electrical & Vacuum Troubleshooting Manual via Ziggy⚠⚠⚠ @
1979 Ford Bronco Wiring Manual pictures, videos, and sounds | SuperMotors.net
It shows Electrical component location, operation, troubleshooting, with wiring and vacuum diagrams.
1979 Ford Bronco Wiring Schematics, Connector Pin-outs, etc by Ranger429 @ 79 wiring schematics
1979 Bronco Brochure @ http://www.auto-brochures.com/makes/Ford/Bronco/Ford_US Bronco_1979.pdf
1979 Ford Bronco vs. Blazer Article by Ford via Indybronco @ 1978 Ford Bronco Bronco vs. Blazer (79) pictures, videos, and sounds | SuperMotors.net
Ford Shop Manual Diagrams: 1978-1979 Full Size Shop Manuals, partial @ Technical Diagrams Archives
My Tablet takes hours to download, so try the first in this list as long as you have Adobe Acrobat 9 or later installed.
Includes:
Wiring Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Rear Lights Diagram
Motor Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Air Cleaner Diagram
Chassis Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes '78 Brakes Diagram, Gas Tank Setup Diagram
Body Manuals & Diagrams Download PDF This complete manual for the 1972-1979 Ford Bronco Includes; Upper Body Diagram, Front Clip Diagram, heater Ducts Diagram, Tailgate Diagram, Console Diagram, Front Clip Diagram, Grill Setup Diagram, Heater Controls Diagram, Interior Trip Diagram, Rear Sheetmetal Diagram, Tiltwheel Diagram, Tire Rack
Let me know if the downloads are worth the effort.
See Bubba's M-Block Ford V8 Workshop by Dave Resch
Partial Chilton Manual for 1978, 1979, 1980, 1981 Bronco. Scanned by broncocity.com @ Bronco City
For any Bronco questions or to chat about it's planned build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as 1978-'79 Bronco Tech that requires 30 posts to view or post) .
Or 1978-'79 Bronco Tech, Bronco and Ford Parts/Accessories (75 posts required to participate due to scammers who preyed on our members. .
To save you time and for better responses, please fill out your Signature with location, year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. .
Our Forum FAQs includes for example, How to Use Search and more tips!
See Baba Looey's Favorite FSB Links (lots and lots of tech links)
➡ Try to find time to participate in and Vote in our Full-Size of the Quarter & Full-Size of the Year Contests @ Voting
You will get ideas by those competing. Also see the prizes! They are awesome as compared to other sites' "contests"!
Al
Believe it or not the new motor made in China works a lot better that the original stock rebuilt motors from Napa auto. I hate to say that but it’s what I found
Just my experience
1 - 4 of 4 Posts
