Rear View Mirror Connector
3406 Views 10 Replies 3 Participants Last post by  miesk5
I'm assuming that this connector is the same for all fords and If I find this 3 pin connector in a Junk yard I can clip it off and splice it into my harness? One of hte previous owners had sniped it. I'd Like to wire it back in.
1 - 11 of 11 Posts
yo!
Doesn't appear to be a common conn; I went thru a few Ford pig tail/ connector sites and its a no go; (PICO) and Ford http://www.p71interceptor.com/motorcraftpigtails/Wiring_Pigtails_Catalog.pdf
Connector Face Pinout (C913) Diagram in 94-96
Should be = to any sim year F or E series though.
GL!
I've yet to come across the 3 pin Gentex connector in the junkyard. I can find 5, 7, and 16 all day long, but not the 3.
I've actually installed a Gentex 177 in the Bronco that uses the 7 pin connector but one of these days I'm going to try cutting down a 5 or 7 pin connector to 3 to see if I can get the Bronco-correct autodimming mirror to work.
In case you don't already have it, looking at your picture, from L to R, it is 12v (key on), ground, reverse indicator.
yo
Found it in Motorcraft Pigtails Catalog @ http://www.fordinstallersupport.com/files/catalogs/wpt200.pdf
Altho 96 MY is not listed; Ford wrote the broncos and other not-in-production models and does not bother updating on-line catalogs
WPT-584 Color: Black
Gender: Male
Contact Mirror — Rearview (Electrochromatic
Listed for (can get from yard from these)
FORD
Crown Victoria ................................2004-93
LINCOLN
LS.......................................................2000
MERCURY
Grand Marquis .....................................1993
Light Truck
FORD TRUCK
Bronco ...........................................1995-94
Excursion .......................................2003-00
F Series .........................................1997-94
MOTORCRAFT Part # WPT584 {#3U2J14B475PSA, 3U2Z14S411PSA} @ ROCK AUTOCategory: Pigtail
$19.89
Found a listing for up to 96
$19.99:shocked
YO J!
yep; figures, huh? But that listing gives a clue as to what Fords/years have em; so a yard search will help
I use; http://www.mypartshop.com/
Select Ford Truck
& since they don't list mirror, rearview or electroc... I usually select Power Window Motor to bypass XL models (like mine)
Yeah, I'll have to cruise the crown vics and grand marquis at the yard.
Thanks Miesk5 That will help alot when I go to teh Junk yard. was planing on goin sat afternoon, but was to tired after work.
yw Ewgoetz, GL
Found a Rear view mirror Connector today on a 90 TBird.
Also can across a door Light bexel off of a 94 F350.
Paid 2 Bucks for them both.
great!
and Ford doen't list the bird in their catalog; so you made a new find!
1 - 11 of 11 Posts
