Im thinking about running new wires from the dash switch to the rear window motor because something between there aint getting power.Where are the wires for the rear window located or is their something in between their that went bad?
If you looked through steve83's pics I am quite sure you have seen it. It is inside the tailgate.....if your standing behind the truck looking at the (closed) TG, it would be in the upper left hand section.94Beast said:Do you know where that safety mechanism is located?
Well about 2-3 feet away from where your tailgate motor is located is that switch that disengages when the latch isn't fully closed. (Well that's how its supposed to work in theory) I bypassed my switch.94Beast said:Ok the guy im getting it from said it has power till about 3 feet from the window could it still be the same problem?
