Yes, I did a search.
I am in the final phase of completing my resto. After some test driving, it's kicking out a Code 41. (Lean condition) Check engine light comes on after run on the freeway for 5-10 minutes. There were NO code issues with the old engine. The engine (long block) was rebuild professionally and I reinstalled the upper intake and peripherals. Timing is at 10 BTDC and vacuum at idle is 16. FPR is new(er) and front fuel pump is NOS. Idle is a little lumpy but it may be the new cam profile. Fuel injectors are new from Ford and are purple vs the old orange.
EGR sensor and controller are new. EGR seems to be working fine. I think I read somewhere that the lean condition could be caused by the EGR sticking open. I assume it's ok b/c I put vacuum on it at idle and the engine faultered.
I havent spent a lot of time on it - but was looking for some guidance (shortcut) on what typically goes wrong to cause this code on Broncos.
Thanks
Thanks
