Well got my tranny back in the FSB yesterday and all 15.5 quarts of ATF in her(actually all 16) but the first thing I did was let it Idle for about 10 minutes to let the assembly grease melt down. I put her in drive and all i got was in and out of drive feeling like a tug in and out of drive, it got better as i drove her down the street till it just felt right, while in 3rd I floor it to check the kickdown, it worked and shifted back into third all of a sudden i get to the stop and its just slipping. I put her in 1st and that works fine, then to second and also fine back to Drive with OD activated and still slipping I then disable OD and it works, kinda sluggish but it shifts. I havent got any code from it but could it be the new MLPS is not adjusted correctly?????? any help would be appreciated. If anything i will just pull the tranny again and check for a loose snapring or stuck valve. :duh
