1 - 20 of 28 Posts
I love it but of course there’s a small list of things to take care of, like the drivers side door not opening at all.
the cable is evidently detached from the handle. Inside handle is broken off and the classic thumb button mechanism is sticking on the outside.
therefore, door is stuck closed.
I need help with getting this door open and the side panel off to replace the necessary parts.
I only know a little as far as mechanics however I have a high learning curve so I’m doing some research and reaching out to people like you that are smarter for advice.
thank you folks
can't help ya on the door, but it looks clean. nice find, and best of luck turning it into a great daily driver or off road beast or whatever your intentions.
Yo ElectricVegetable,
Welcome and congrats on acquiring the best year Bronco!
166894
ItemPart NumberDescription
120124Front Door
221852Front Door Latch Push Button Rod
322152Front Door Latch Actuating Rod
422134Front Door Latch Control Cylinder Rod
5218A42Power Door Lock Actuator
6W701566-S417Rivet
721818Front Door Latch Remote Control and Link
8389760-SClip
9386656-SBushing
10219A36Retainer
11391564-SBushing
12N800510-S100Screw and Washer
13N623332-S100Nut
14N806046-S301Nut and Washer
1522448Pad
1622404Door Handle
1722428Outside Door Handle Large Pad
18N811306-S3Screw and Washer
1921985Door Lock Cylinder
20220A96Retainer
ATighten to 9-14 Nm
(80-124 Lb-In)
BTighten to 7-11 Nm
(62-97 Lb-In)
For parts,
For a YARD SEARCH on-line, I use;
Hollander Quality Replacement Parts | Find Used Auto Parts | Online Locator
A yard that uses Hollander Interchange can search other yards and have it shipped including some Canadian yards.
"...For over eighty years, Hollander has been making the best tool for fast, interchangeable part matches. The new Edition Hollander Interchange contains more interchangeable options than ever before.
The Hollander Interchange provides auto recyclers and auto collectors, rebuilders, and others with the easiest and most comprehensive solution for identifying interchangeable auto parts..." See their yard Directory @ Seller Directory | Used Auto Parts | Hollanderparts
Can select a certain part.
If a specific part isn't listed, search again for the next higher assembly, such as in this instance, Search: 1996 >Ford > Bronco > Doors > Door Handle Interior > Alternate Door Handle Interior
ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
To confirm current status, use this guide by jowens1126 @ 93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
For any Bronco questions or to chat about it's planned modifications, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (75 posts required to participate due to scammers who preyed on our members.).
On that first page, named Account Details,
scroll down to "Vehicle Info" and type in up to 100 characters.
See Baba Looey's Favorite FSB Links (lots and lots of tech links)
Here's the 1996 Bronco/F-Series Workshop Manual partial
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @ 1996 Ford Bronco Technical Info pictures, videos, and sounds | SuperMotors.net ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site .
See our Sites' FAQs, includes for example:
How To Save (Bookmark) Threads Or Posts
How To Search The Site
What is the Difference Between the Showcase and Gallery
Try to find time to participate and vote in our current Full-Size of the Month Contest & later in the year, Full-Size of the Year Contest @ Voting
You will get ideas by those competing. See the prizes!
Al
1991 Ford Bronco, w/95frontclip, 6"Superlift, Deaver J40 springs, 35x12.5 K&N, 3"Bassani
There is a chance that you are having trouble opening the door from the inside not because the cable is disconnected (but very well could be this) but because the metal the handle mounts to has fatigued to the point of breaking. Solo motor sports makes a reinforcement plate that rivets in place and adds structural integrity. This is a common problem with the handles breaking loose and leaving you to open the door from the outside. I bought two of these and reinforced both sides. Everyone should do this because it is just a matter of time before the factory metal will break.
Reactions: miesk5
Yo,
Trim Panel, Door
Section 01-05: Trim, Interior
REMOVAL AND INSTALLATION
Procedure revision date: 05/18/2000
Trim Panel, Door
Removal
  1. Remove screw(s) retaining the front arm rest pad (24100) to front door trim panel (23942).
  1. Remove screw retaining inside door handle (22600). Remove inside door handle.
  1. Remove the screw retaining window regulator handle, if equipped. Remove window regulator handle and washer.
  1. If equipped with power windows, remove window regulator switch housing (14527). Refer to Glass, Frames and Mechanisms.
  1. If equipped with power door locks, remove the power door lock switch housing. Refer to Handles, Locks, Latches and Mechanisms.
  1. Remove door lock switch (14028), if equipped. Refer to Handles, Locks, Latches and Mechanisms.
  1. Remove outside rear view mirror control (17B676), if equipped. Refer to Mirrors, Rearview.
  1. Carefully pry front door trim panel and pushpins away from front door trim shield (237A04), using Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent. Never pull on front door trim panel to remove pushpins from front door trim shield.
Installation
  1. Follow removal procedures in reverse order.
  1. Tighten screw and washer assembly 1-2 Nm (9-18 lb-in).
    Trim Panel, Door
    1237A04Front Door Trim Shield
    256914-S58Screw and Washer (2 Req'd Each Side)
    324022Armrest Support
    4642A54Map Pocket Assembly
    5N802900-SPushpin (5 Req'd Each Side)
    623942Front Door Trim Panel
    756914-S58Screw (1 Req'd Each Side)
    8N806578-S58Screw and Washer (1 Req'd Each Side)
    9N802539-S100Spring Nut (2 Req'd Each Side)
    ATighten to 1-2 Nm
    (9-18 Lb-In)
    Trim Panel, Door, Hi-Series
    1Window Regulator Control Wiring (Part of 14630)
    2237A04Front Door Trim Shield
    314527Window Regulator Switch Housing
    456912-S58Screw (1 Req'd Each Side)
    556914-S58Screw and Washer
    6N801925-SPushpin (5 Req'd Each Side)
    7N805121-S303Screw and Washer Assembly (4 Req'd Each Side)
    823942Front Door Trim Panel
    955928-S2Screw (3 Req'd Each Side)
    10N806578-S58Screw and Washer (1 Req'd Each Side)
    11N802539-S100Spring — Nut
    1224022Armrest Support
    ATighten to 1-2 Nm
    (9-18 Lb-In)
Thank you! It is a beast I look forward to getting on a trail or two in my favorite spots.
I am confused it looks like the door is open. Getting the panel off with the door close is going to be a trick there is a screw on the top dash side that is buried IIRC when the door is closed
The picture is misleading. I posted the one picture of it before the door mechanism finally broke...apologies
120124Front Door
6W701566-S417Rivet
8389760-SClip
9386656-SBushing
10219A36Retainer
11391564-SBushing
13N623332-S100Nut
1522448Pad
1622404Door Handle
20220A96Retainer
ATighten to 9-14 Nm
(80-124 Lb-In)
BTighten to 7-11 Nm
(62-97 Lb-In)
For parts,
Al
Wow thank you. Appreciate all resources and information shared.
Yo,
Trim Panel, Door
Section 01-05: Trim, Interior1996 Bronco/F-Series Workshop Manual
REMOVAL AND INSTALLATIONProcedure revision date: 05/18/2000
Trim Panel, Door
Removal
Installation
    Trim Panel, Door
    ATighten to 1-2 Nm
    (9-18 Lb-In)
    ATighten to 1-2 Nm
    (9-18 Lb-In)
Sorry for the misleading picture but first I have to get the door open. Handle broke off and outside handle is broken.
Yo E,
I haven't found a way to remove the panel without damage. Try asking at a local body shop,
Try removing the window/door lock switch assembly. You can do this with door closed and door panel on. That will give you a little window to what's going on behind the panel and you should be able to grab the back side of door handle.
Discussion Starter #13
I will make this happen thank you.
1995 XLT SAS w D44 and D60 rear
Perhaps you can take the key cylinder out of the door. That might give you a space to manually pull the door mechanism from outside. Oh wait, shit the door has to be open to get that out to.Someone who is good with a slim jim? If they can get to the latch that might be your bet.
This is your best bet...
Yo,
FYI,
Lock Cylinder, Door
Section 01-14A: Handles, Locks, Latches and Mechanisms
Lock Cylinder, Door
NOTE
NOTE: When a door lock cylinder (21985) is replaced, both door lock cylinders should be replaced in a set. This will eliminate carrying an extra key which will fit only one lock. If a key is to be replaced, the new key code number is stamped on a metal tag attached to the key.
Removal
  1. Roll the window up.
  1. Remove access hole cover and/or front door trim panel (23942) and pull away watershield, if equipped. Refer to Trim, Interior.
  1. Disconnect the front door latch actuating rod (22152) from the lock door latch operating lever.
  1. Slide the lock cylinder retainer away from the door lock cylinder.
  1. Remove the door lock cylinder.
Installation
Do not do anything dumb like cut the door panel. Remove the screws from the door panel and the window switch.
use the plastic puller for lifting the door switch panel. Use the plastic for prying against plastics. Use the metal puller for going up under the the door panel. Along each side there is door panel retainers slide the puller behind the door panel till it hits a retainer. Carefully pry the door panel away from the door shell with the puller. Continue sliding down and across to each door panel retainer. Once you have done both sides and the lower side and the panel is loose not attached to the door then move the door panel upwards and off and around from the door lock indicator from above. Slide the door panel off of the inner door handle. Carefully pull upward and then reach behind the door panel and unscrew the window switch panel with a Phillips screw driver. Door panel should be removed now.
Find the latch pull downward on the arm the inner handle rod attaches to and it should open. Lubricate the door handle, latch and the rods and cables!! Pb blaster, deep creep, lithium spray grease etc. install new door panel retainers they are cheap on ebay and clipsansfasteners.
How do you get to the screw that sits right behind the dash in the top right corner of the panel? With out removing that it will be very hard to get the panel off.
1984 Bronco, 4.9L, C6, 8.8, 44 TTB, 3.54 Gears
Can you unscrew and remove the dash panel? I know I'm able to on my 84'. Might allow access.
1 - 20 of 28 Posts
