1 - 8 of 8 Posts
Ok just changed out the back window motor. I have determined it is my regulator that is froze up... Any trick to get it to work?
take it apart and lubercate it.
Other wise your motor is seized up
I just put a new motor in it. I assume it is the regulator arms at least that is what it feels like
Are you sure the motor is recieving proper voltage and current. A bad connection or broken wire will stop the motor.
it may work fine with no load, but if the wires cannot carry the amps needed to make it move the window it will not work
Idk i had someone hold down the button and I pulled down on the arms and it would not budge...
1 - 8 of 8 Posts
