1 - 10 of 10 Posts
anyone have a pic of their back bumper off.. i have 3' body lift and im thinkin bout just taken it off instead of fabricating it too fit...i just want to see what it looks like
The back is simple, you lift it up 3" the bottom bolts line up with holes in the frame, and all you need is an L bracket to sit on the top of the frame to mount the upper bolt in. Bolt the L bracket to the frame and then to the bumper your set.
They're called bumper relocating brackets. Check any place that sells body lifts.
I had my brother make them, works at a machine shop :rofl: Angle iron cut down, drill a couple holes. Scrap angle iron from a shop, you don't need much. Bumper relocation brackets, $24.99 or more, angle iron 5 bucks :histerica
You don't even have two make any. Just use the stock ones, all you have to do is flip them over & swap sides. Then drill another hole & thats it.
Check your local laws I believe it is, because, in an impact, it's pretty much, "hello, gastank":toothless
1 - 10 of 10 Posts
