I know I will need shorter bolts. Has bumper brackets those should just come off then bumpers back on? I also have a manual, ckutch linkage?
Thanks
Lick my balls
Why don't you just crawl under your truck and look. All the answers are there for you and if you over look the answer to one of your concerns or over look a question, it is very likely an easy fix. Just get new bolts after looking at the current set up and go to town on saturday morning.
ALSO, your linkage shouldn't be an issue, just re-adjust it, but as long as you look at what the set up is now and what may be encountered, you should be ok.
Because I'm 15 minutes away from my truck and was just making sure I have everything I need before I drive out there. My main concern was just the clutch linkage. Thanks
you have to cut your clutch rod, and shorten it the amount of the body lift, (the rod that goes threw the floor, to the z bar)
Well my clutch is hydro..
Wrenching for a Livin'
