1 - 10 of 10 Posts
Does anyone know what type of product that would remove raddle can paint from a fiberglass top and want damage the fiberglass. I want to Durabak the top of my 78 bronco and want a good base to work with. Thanks
green ones make me horny
acetone might but i dont know what it will do to fiberglass. i would just sand it down.
3 wheeler
get some fiberglass paint remover. I got some at a sherwin williams paint store stuff works like a charm. Best paint remover I have every used. If it is rattle can paint then that stuff will come up super easy. Just use all the pre-cautions on the label cause that stuff will eat you up. Personally I durabaked a truck one time, I'm still not sure if i liked it. The product is great, went on good. But, it is rough and suprisingly not that easy to clean.
nbaffs
Did you use the durabak on the outside or inside. They make smooth or rough texture with a UV protectent. What did you use. I'm going to use the smooth.
Chaos is coming!!
I would sand it down....if your going to refinish it, it will need to be sanded anyway. Then put a good sealer on it and finish coat it in whatever you want.
I wouldnt even go through all that trouble. I would just get another top. People are always looking to give one away! :thumbup
79f150
I located in springville,al 30 miles northeast of B'ham on I-59. What type of conditon is the top in. Mine is in good condition just the wrong color. Does your top have the sliding windows the top I have has the sliding windows.
Designated Tranny Killer
I'd say sand it
Lick my balls
Unless you painted it without sandind it, I wouldn't attempt to remove the paint that is there, just resand it and paint it again with what ever you want to use..
1 - 10 of 10 Posts
