Removing range box from NP-203??
1221 Views 3 Replies 2 Participants Last post by  Larston
like the title, how do I complete the job,I got it to slide like an inch off. I asked this on Sat in emergency help but got no replys when so many people have done this
And while your at it since you can answer this question, you probably know the answer off the top of your head. What do I need to send the guy, case, bearing, tranny adapter??
1 - 4 of 4 Posts
It's been a while since I did mine so I don't remember the details, but you need to disconnect the 4WD shifter from the main case. You'll have to go inside the main case to do it as there's a link or roll pin that retains it. It's not hard to do, just messy. You'll end up with rolller bearings everywhere by the time you get done. Once you get the main case disconnected, you'll have to disassemble the range box to completely remove the 4WD shift rail, but leave the shift lever in the range box case as it seals the range shift shaft.
Depending on where you're getting your adapter kit, they should only need the output bearing retainer from the range box and intermediate shaft between the range box and the main case. It's best to call the vendor and ask exactly what they need.
When you disassemble the range box, remove the retainer that holds the idler shaft in, then pound the idler shaft out in that direction using a large hammer and a soft drift (brass is best.) Be damn sure to watch how the parts come out as there are two thrust washers and two rows of roller bearings with a spacer inside the idler gears that have to go back exactly as they came out or you'll destroy the range box when you get it running again.
Holy crap glad I asked
Edit, can I leave the 4wd shift rail in the case for the guy im selling it to or will it save significant weight???
Won't make any difference weight wise. The rail is about 4 or 5 inches long and 3/4 inch in diameter. You'll need to make sure it doesn't poke a hole in the box halfway across the country, though. The UPS guys get pissed when you hurt them with protruding metal parts :toothless
1 - 4 of 4 Posts
