I supposed you'd leave the old timing set in the engine if you had the front cover off, too? After all, if they're working, leave 'em in, right? Oil pumps NEVER wear out, do they? :scratchheDcSkater602 said:so if he throws a bad pump in and has to take it apart again he is screwed...if it works id leave it...just my opinion...plus its a bitch while the motor is in the truck unless you can get the pan all the way out...
btw 2 bolts and the bolt for the pickup total 3
dc
Larston said:I supposed you'd leave the old timing set in the engine if you had the front cover off, too? After all, if they're working, leave 'em in, right? Oil pumps NEVER wear out, do they? :scratchhe
If it were mine, I'd replace the pump and go a step further and drop a couple main caps to check the bearings as well. It's a great time to see if you're due for an overhaul.
DcSkater602 said:im just the kinda guy who has a perfectly running 302, with anew cranka nd oil pump and decides that since the motor mounts are blown...im gonan do a 5.8 swap w/ a full rebuild..:shrug ...makes sense to me for some reason:wacko i still haven't understood the saying "IF IT AINT BROKE DONT FIX IT!"
if you have the money and the mechanical ability i agree fully what larston says...if you dont know what your doing i would leave it or start learning...go to the write up about oil pumps in the tech section to get a basis of what you getting into..but if you dont know what your doing i would leave it bc believe it or not oil is rather important:thumbup
dc
Goose said:yeah I got a idea whats goin on and am very mechanically inclined. Its also not my daily driver so it doesn't hurt to have it down for a week or more. I'll glance at things once I drop the pan completely and go from there. Who wants to bet on how many bolts I break in the manifolds? Quick clue, no torch available :banghead but they are soaked with penetrant (seafoams to be exact):beer Thanks for the input:thumbup
Goose said:I've got a 2" body lift so I'm gonna chance it and say that I dont have to take off the intake. I'll post up and say if it works out ok when I lift the motor. The bolts I was refering to were the exhast manifolds to Y-pipe, stupid studs are rustyand dont look pretty, thanks to the salt they use here all the time.
