1 - 4 of 4 Posts
Replaced 33 gallon tank with a plastic 25 gallon tank.
Gained 4 inches of clearance, new sending unit and now have a 1/4" skid pan under it.
New sending unit didn't cure my gauge though.
Wiring all looks good.
Gauge will read full when you fill it up but drops to E when it should read 3/4.
Are there any replacement gauges available or is it time for a summit gauge.
And i don't suppose anyone knows where i can get a replacement for the small plastic filler line that runs inside the larger one. When i got my new rubber line from Bronco Graveyard i just cut the one on the Bronc in half to speed up the tank removal process:banghead
Sounds like a bad sending unit to me.
should have clarified ...
nothing changed with the new sending unit ...
when you fill the tank the gauge goes to full ...
as soon as you use a few gallons it drops to E ...
1 - 4 of 4 Posts
