1 - 2 of 2 Posts
I've gotten my hands on a "working" 4WABS computer I am going to install. Since the original has never worked I have the module bypassed to get signal to the E4OD. If I'm going in to undo the bypass to test out the replacement 4WABS, I'm wondering if there is a way to run the 4WABS like the RABS wiring so when the 4WABS fails (assuming this one works) the signal will still get to the PSOM? If this is the case then is it also worth putting a kill switch in to disable the 4WABS (assuming I'd be able to get the VSS signal to the PSOM in both scenarios)?
162513
162514
Does the 4WABS rely on the return signal from the PSOM? If I were to terminate 491 and connect it to a split 519? I guess it all depends on what the 4WABS requires for inputs (21, 14/1?).
162517
Discussion Starter #2
I decided to install a couple of connectors on the vss wires and colour code the sets before they reach the 4WABS. If this module goes I can just plug the connectors direct from VSS to the PSOM without any interference.
1 - 2 of 2 Posts
